| Велосипед Apollo |
СообщениеДобавлено: 17.12.2024 14:32
Репутация продавца: 278
  • 1
Телефон для связи: +380983989798
Новые запчасти для вилок DVO: Diamond D1, Diamond, Onyx SC, Onyx DC, Sapphire D1, Sapphire 32, Emerald.
Штаны с бушингами и пыльниками:
Diamond D1/Beryl 27.5" Boost Bottom Case Assembly Green. Part Number: 1619000-TC704 - 4500грн
Diamond D1/Beryl 27.5" Boost Bottom Case Assembly Blue. Part Number: 1619000-YS9429-X2 - 4500грн
Diamond 27.5" Bottom Case Assembly Black. Part Number: 1439100-YS727 - 4500грн
Diamond 27.5" Bottom Case Assembly Green. Part Number: 1439100-TC704 - 4500грн
Onyx SC 27.5" Bottom Case Assembly Black. Part Number: 1669000-YS727 - 6000грн
Onyx DC 27.5" Bottom Case Assembly Black. Part Number: 1659000-YS727-X3 - 7000грн
Onyx DC 27.5" Bottom Case Assembly Green. Part Number: 1659000-TC704-x3 - 7000грн
Onyx DC 27.5" Bottom Case Assembly Blue. Part Number: 1659000-YS9429 - 7000грн
Emerald Upper Leg Assembly Black. Part Number: 1419013-JY001 - 4600грн
Emerald CTA Assembly 26". Part Number: 1419010 - 5100грн
Sapphire D1 29" Boost Bottom Case Assembly Black. Part Number: 1889000-YS727 - 4500грн
Sapphire 32 29" Boost Bottom Case Assembly Black. Part Number: 1639000-YS727 - 2800грн
Ноги+корона+шток:
Sapphire 32 Boost Upper Assembly Brown. Part Number: 1639001-AK20M - 3500грн
Sapphire 32 Boost Upper Assembly Green. Part Number: 1639001-TC704 - 3500грн
Sapphire 32 Boost Upper Assembly Black. Part Number: 1639001-YS727 - 3500грн
Diamond D1 Boost/Beryl Upper Assembly Green 44/51mm. Part Number: 1619001-TC704 - 7000грн
Diamond D1 Boost/Beryl Upper Assembly Black 37/44mm. Part Number: 1619001-TC704 - 7000грн
Diamond D1 Boost/Beryl Upper Assembly Black 44/51mm. Part Number: 1619001-YS727 - 7000грн
Diamond Upper Assembly Green. Part Number: 1439001-TC704 - 7000грн
Diamond Upper Assembly Black. Part Number: 1439001-YS727 - 7000грн
Другое:
Демпфер Diamond / Diamond D1 Damper Complete. Part Number: 1619002 - 7200грн
Демпфер Diamond / Diamond D1 Compression Comp Assembly. Part Number: 1439003 - 4100грн
Демпфер Sapphire D1 Compression Assembly. Part Number: 1879003 - 4100грн
Демпфер Sapphire 32 Compression Assembly. Part Number: 1639003 - 2500грн
Демпфер Onyx DC Comp Assembly. Part Number: 1659003 - 4100грн
Демпфер Onyx SC Comp Assembly. Part Number: 1669003 - 4100грн
Воздушная пружина Beryl 29" Air Cartridge. Part Number: 1799006 - 4000грн
Воздушная пружина Beryl 27.5" Air Cartridge. Part Number: 1789006 - 4000грн
Манжета Diamond / Diamond D1 / Beryl Damper End Cap. Part Number: 1439008 - 600грн
Пыльники Diamond / Diamond D1 / Beryl Seal Kit 35mm. Part Number: 1439016 - 780грн
Пыльники Onyx DC/SC Seal Kit 36mm. Part Number: 1669010 - 780грн
Пыльники Sapphire D1 Seal Kit 34mm. Part Number: 1879005 - 750грн
Груша Diamond / Diamond D1 / Onyx DC / Onyx SC / Beryl / Sapphire / Sapphire D1 Bladder Kit. Part Number: 1439013 - 600грн
Щиток Diamond Fender Kit. Part Number: 1439009 - 510грн
Крутилки Onyx DC Damper Knob & Detent Kit. Part Number: 1659018 - 735грн
Крутилки Diamond / Diamond D1 / Onyx SC Damper Knob & Detent Kit. Part Number: 1439018 - 735грн
Поршень Sapphire 32 Air Piston Kit Sapphire. Part Number: 1639015 - 630грн
Поршень Onyx SC Air Piston Kit Onyx SC. Part Number: 1669008 - 750грн
Крышка Sapphire 32 Air Cap. Part Number: 1631082 - 380грн
Ось Onyx SC 110х15. Part Number: 1669011F - 1500грн
Топкеп Onyx DC Air Volume Assembly. Part Number: 1659008 - 650грн
Топкеп Onyx SC - 650грн
40
dvologo.jpg [ 83.42 КБ | Просмотров: 1532 ]
Тема поднималась пользователем dybby1 17.12.2024 14:32.
[ Time : 0.087s | 16 Queries | GZIP : On ]
