| спальный мешок купить |
СообщениеДобавлено: 28.10.2025 11:24
Репутация продавца: 33
Телефон для связи: О93,14О,65.54
Шосейні втулки Roval CLX disk ceramicspeed ціна 6900грн
Front Hub: Roval AFD1, Centerlock, CeramicSpeed bearings, quick-release or 12mm thru-axle end cap
Spoke Pattern: Two-cross/Radial (2:1)
Spoke Count: 21 Spoke Type: DT Swiss Aerolite (L)/Aerocomp (R) T-head
Rear Hub: Roval AFD2, Centerlock, CeramicSpeed bearings, DT Swiss 240 internals, 11-speed, quick-release or 142x12mm thru-axle end cap
Spoke Pattern: One-cross/Two-cross (2:1)
Spoke Count: 24 Spoke Type: DT Swiss Aerocomp (L)/Aerolite (R) T-head
ширина 100*12/142*12мм
ціна колеса на сайті specialized
https://www.specialized.com/ua/en/roval ... 30017-7902
https://www.specialized.com/ua/en/roval ... 30017-8001
Шосейні втулки Roval CLX ceramicspeed ціна 4900грн
перід 16 спиць straightpull Radial
Front Hub: Roval AF1, CeramicSpeed bearings
зад 21 спиці straightpull Radial/Two-cross (2:1)
Rear Hub: Roval AF1, CeramicSpeed bearings, DT Swiss 240 internals, 11-speed
ширина 100/130мм
https://www.specialized.com/ua/en/roval ... 30017-7702
https://www.specialized.com/ua/en/roval ... 30017-8201
ширина 100/130мм
https://www.specialized.com/ua/en/roval ... 30017-8202
Шосейна втулка Roval CL 50 disk ціна 3000грн
Rear Hub: Roval AFD2, Centerlock, sealed cartridge bearings, DT Swiss 350 internals, 11-speed, quick-release or 135x9mm end cap
Rear Spoke Pattern: One-cross/Two-cross (2:1)
Spoke Count: 24 rear
Rear Hub: Roval AFD2, Centerlock, sealed cartridge bearings, DT Swiss 350 internals, 11-speed, quick-release or 142x12mm thru-axle end cap
Spoke Count:, 24 rear
барабан Sram XDr
Шосейна втулка Roval CLX disk ціна 4000грн
Шосейна втулка Roval CL 50 ціна 2500грн
Rear Hub: Roval AF1, sealed cartridge bearings, DT Swiss 350 internals, 11-speed
зад 21 спиця straightpull Radial/Two-cross (2:1)
Гальмівні колодки від 55 гривень. AVID, Shimano, FORMULA, HAYES, Magura, Tektro, Promax, Clarks, Hope та інші.
Ліхтарики CONVOY Sofirn зарядні пристрої, акумулятори, аксесуари
Тема поднималась пользователем sergij77 28.10.2025 11:24.
[ Time : 0.254s | 14 Queries | GZIP : On ]
