Все вопросы по телефону 0975356818Оригинальный Shimano SM-RT70 Ice-Tech Center Lock w/ External Teeth 180мм. Новый.Цена: 1300 грн.Technical Information:Mount: Center Lock
Diameter: 180 mm
Design: 2-piece
Rotor Material: stainless steel outer and aluminium core sandwich construction
Spider Material: aluminium
Brake Compatibility:BR-M9100, BR-M9120, BR-M9000, BR-M9020, BR-M8100, BR-M8120, BR-M8110-R, BR-M8000, BR-M8020, BR-M7100, BR-M7120, BR-M7110-R, BR-M7000, BR-M6100, BR-M6120, BR-M6000, BR-MT520, BR-MT420, BR-M820, BR-M640, BR-S7000, BR-U8000, BR-U8020, BR-S700, BR-R9170, BR-R8170, BR-R8070, BR-R7170, BR-R7070, BR-4770, BR-RS805, BR-R785, BR-RS785, BR-RS505, BR-RS405, BR-RX820-LE, BR-RX810, BR-RX400
Technology:Ice-TechShimano Ice Technologies provide a fast heat dissipation at your disc brake. The brake pads are equipped with aluminium cooling fins. The brake rotor is constructed using a sandwich technique in which stainless steel encloses an aluminium core. The stainless steel on both flanks ensures long durability, the aluminium allows heat dissipation.
Manufacturer Numbers:180 mm: I-SMRT70ME
Contents: 1 x Shimano SM-RT70 brake rotor
1 x lockring with external teeth
Weight: silver/180 mm: 159 g
3.JPG [ 274.71 КБ | Просмотров: 11367 ]
Другие мои темы:Покрышки Continental Cross King 2.2 Performance TLR 29x2.2" Folding:
viewtopic.php?f=2687&t=523099Цепи DEORE CN-M6100 12-speed и SLX CN-M7100 12-speed:
viewtopic.php?f=2699&t=524525Флягодержатель алюминиевый чёрный:
posting.php?mode=edit&f=83&p=2111235Ротор Shimano SM-RT70 Center Lock w/ External Teeth 180мм. Новый:
viewtopic.php?f=2689&t=511709Зажимы подседелки 34,9 :
viewtopic.php?f=2674&t=471468Оливка + штуцер Shimano (для SM-BH59):
viewtopic.php?f=2695&t=468702Эксцентрик Shimano задний, как новый:
viewtopic.php?f=2701&t=471473
