| велосипед купить кременчуг |
СообщениеДобавлено: 12.11.2013 00:19
РАМА 26" MTB, 6061 Alloy Super Lite Tubing, T4/T6 Heat Treated, Fluid Forming, Double Butted, 3D-Dropout, Allround Geometry
РАЗМЕР РАМЫ 38/42/47/51/56 cm
ЦВЕТ Black / Red / Grey (Matt)
ВИЛКА Suntour XCM HLO 26", 1 1/8", 100mm, Coil, Hydraulic Lockout
РУЛЕВАЯ КОЛОНКА BGM Comp, A-Headset, Semi Integrated, ZS44/28.6 | ZS44/30 (1 1/8")
РУЛЬ BGM Comp, Riserbar, backsweep: 9°, rise: 15mm, width: 660/680mm for 38-42/47-51cm
ГРИПСЫ BGM Comp, MTB, Double Density
ВЫНОС BGM Comp, 7°, length: 75/90/105mm for 38/42-47/51cm, clamp diameter: 31.8mm
СЕДЛО BGM Comp, MTB
ГЛАГОЛ BGM Comp, 2-Bolt Design, 31.6mm, length: 300/350mm for 38/42-51cm
ЗАДНИЙ ПЕРЕКЛЮЧАТЕЛЬ Shimano Deore, RD-M591, SGS, Top- Normal
ПЕРЕДНИЙ ПЕРЕКЛЮЧАТЕЛЬ Shimano FD-M370, 34.9mm Clamp, Top-Swing
МАНЕТКИ Shimano Acera, SL-M370, 3x9-speed, Rapidfire-Shifter
ТОРМОЗА Tektro HDC 300, hydraulic Disc Brake, Rotor: 180/160mm
ТОРМОЗНЫЕ РУЧКИ Tektro HDC 300
ВТУЛКИ пер: BGM Comp, 6-Bolt, Disc, Quick Release, зад: BGM Comp, 6-Bolt, Disc, Quick Release
КАССЕТА Sram PG-950, 9-speed, 11-32t
ЦЕПЬ KMC HG-53, 9-speed
ОБОДА BGM Comp, 26", Disc, 36H
СПИЦЫ stainless, black Color
ПОКРЫШКИ Schwalbe Smart Sam, wired, 54-559
СИСТЕМА Shimano FC-M391, 44/32/22t, length: 170/175mm for 38-42/47-56cm
КАРЕТКА Sealed Cartridge
ПЕДАЛИ Wellgo LU-945, MTB
ВЕС 13.9 кг (47 см)
6200грн
[ Time : 0.079s | 12 Queries | GZIP : On ]
