Правила форума
 Заголовок сообщения: Specialized Roubaix Elite Carbon L
СообщениеДобавлено: 04.07.2019 08:43
Репутация продавца: 1
Год выпуска: 2008-2009
Телефон для связи: 0991181167
В хорошем состоянии, в стоковой комплектации
Рама, вилка, подседел карбоновые.
торг.
https://www.specialized.com/us/en/rouba ... 7529-21813
Technical Specifications
MANUAL DOWNLOADS
DRIVETRAIN
CHAIN Shimano 105, 10-speed
BOTTOM BRACKET FSA MegaExo, integrated exterior cartridge bearings, alloy
CRANKSET FSA Gossamer MegaExo, 2-piece crankset
FRONT DERAILLEUR Shimano 105, 31.8mm clamp, bottom pull
SHIFT LEVERS Shimano 105, 10-speed STI, flight deck compatible
CHAINRINGS 50x39x30T
REAR DERAILLEUR Shimano 105, long cage
WHEELS
FRONT HUB Specialized forged alloy, 24 hole, double sealed bearings, straight pull spokes, QR
REAR HUB Specialized forged alloy, 28 hole, double sealed bearings, straight pull spokes, cassette, QR
SPOKES Stainless 14g, straight-pull
FRONT TIRE Specialized Roubaix Pro, 700x23/25c, aramid bead, 120TPI, Flak Jacket
RIMS Mavic Open Sport, double wall rim, machined sidewalls w/ eyelets
REAR TIRE Specialized Roubaix Pro, 700x23/25c, aramid bead, 120TPI, Flak Jacket
COCKPIT
SADDLE Specialized Avatar, microfiber cover, gel padding, Cr-Mo Rails
STEM Specialized Comp-Set, 3D forged alloy, 4-bolt 31.8mm bar clamp, 4-position adjustable
HANDLEBARS Specialized Zertz Comp, 6061 alloy, Zertz damper, short-reach drop, ergonomic top shaping, 31.8mm
BRAKES
FRONT BRAKE Ultralight dual pivot brakes, Teflon pivots, forged alloy w/ cartridge pads
BRAKE LEVERS Shimano 105, 10-speed STI, flight deck compatible
REAR BRAKE Ultralight dual pivot brakes, Teflon pivots, forged alloy w/ cartridge pads
ACCESSORIES
PEDALS Composite body test ride pedals
FRAMESET
HEADSET Specialized Mindset Plus, 1 1/8"" integrated threadless, cartridge sealed bearings, alloy 20mm cone w/ one 10mm and two 5mm alloy spacers
SEAT BINDER Specialized CNC, alloy, 32.6mm clamp
FORK Specialized FACT monocoque carbon fork, full carbon legs, crown and steerer w/ Zertz inserts
FRAME Specialized FACT 6r carbon, triple monocoque construction, compact design, Zertz inserts
IMG_2142.JPG [ 711.19 КБ | Просмотров: 1076 ]
IMG_2145.JPG [ 611.94 КБ | Просмотров: 1076 ]
IMG_2143.JPG [ 609.42 КБ | Просмотров: 1076 ]
IMG_2144.JPG [ 642.23 КБ | Просмотров: 1076 ]
IMG_2146.JPG [ 634.42 КБ | Просмотров: 1076 ]
IMG_2149.JPG [ 609.42 КБ | Просмотров: 1076 ]
IMG_2151.JPG [ 617.99 КБ | Просмотров: 1076 ]
IMG_2153.JPG [ 590.33 КБ | Просмотров: 1076 ]
IMG_2155.JPG [ 527.66 КБ | Просмотров: 1076 ]
IMG_2156.JPG [ 524.36 КБ | Просмотров: 1076 ]
Тема поднималась пользователем parovoz 04.07.2019 08:43.
Кто сейчас на конференции
Сейчас этот форум просматривают: Alexiz
  © Mishael 2003-2016
forum MAP
[ Time : 0.197s | 17 Queries | GZIP : On | Load : 3.04 ]
