| cannondale trail 7 |
 Заголовок сообщения: Re: ВЫбор еще одного вилсета
СообщениеДобавлено: 21.12.2012 01:51
ну и раскрутить ее во второй раз было сложнее
Т.е. сложнее, конуса все таки зажало?
Или наоборот конус хорошо был зафиксирован фиксирующей гайкой и держал настройку?
Ты не в курсе, где в тех. документации шимано описывается регулировка конуса, а именно какая величина люфта выбирается при затягивании эксцентрика (и выбирается ли он вообще) и с какой силой правильно зажимать эксцентрик?
СообщениеДобавлено: 21.12.2012 02:09
Вот блин, оф дистрибьютор подтверждает наличие проблемы....
Madison UK
Posted Fri 12 Aug, 12:36 pm BST Flag as inappropriate
Thanks for your comments – sorry to hear you've had some negative experience with Shimano products and support.
Just to address a few of the issues raised:
We regularly receive deliveries of spare parts from Shimano. Although shortages can occur on occasion, over the past two years the longest we have not had these spares in stock is 4 weeks. If an order has been placed by a dealer when an item is out of stock, then these will automatically be released and delivered when new stock has been received, so an overall waiting time if we had received an order from a dealer would be no more 5-6 weeks at the very most.
Shimano XT wheels have a two year warranty and go through some of the toughest quality control procedures on the market – if you own a wheelset that has had issues within the warranty period then you can make a warranty claim via your local Shimano dealer.
There was a known issue with the cones on some initial batches of the previous Shimano XT wheelsets. We have since carried out warranty claims and repairs to numerous XT wheelsets that these issues became apparent on.
If you have experienced these issues and your wheelset is still within the warranty period, then please make a warranty claim via your local Shimano dealer.
Thanks
Madison - UK Shimano distributor.
А я 785 втулки заказал...
Сука, обидно... Нада было 756 брать...
СообщениеДобавлено: 21.12.2012 02:40
конус был зафиксирован как я его зафиксировал. правда там пробег был не больше 2000 км.
Я регулирую на грани люфта, тоесть как только ось перестала люфтить зажимаю контрагайку.
Если такая проблема есть, то меня это не особо парит, раз в 2000 км можно и проверить
Веломайстер
Контакти:
СообщениеДобавлено: 21.12.2012 15:53
Люфт нужно проверять непосредственно на зажатом эксцентрике, многие настраивают втулки как попало... а потом говорят, что вся насыпь г и промы рулят :)
vk.com/palermo2400
skype: palermo2400
LinuxUser
СообщениеДобавлено: 21.12.2012 15:54
Кузя, не боись конуса никуда не убегут если все верно затянуть.
vk.com/palermo2400
skype: palermo2400
LinuxUser
СообщениеДобавлено: 21.12.2012 20:57
Если понять причину и пофиксить баг, то не убегут.
К сожалению, гарантийной мастерской, как у англичан, у нас нет.
И раз диллеры признают проблему и констатируют множественные обращения, то это уже не болезнь, это эпидемия.
У кого есть информация о причинах бага?
СообщениеДобавлено: 21.12.2012 22:00
я предпологаю что это из-за алюминиевой оси и алюминиевой контрайгайки. Но я думаю этого бага боятся не стоит. Намного было б прискорбнее если б например вылазили проблемы с барабаном
Веломайстер
Контакти:
СообщениеДобавлено: 21.12.2012 22:17
А в 11-ом году на 775, если я не ошибаюсь, эти проблемы и вылазили, барабан клинило и втулка превращалась в мультискоростной фикс :facepalm:
СообщениеДобавлено: 22.12.2012 00:10
Я знаю людей которые ездят на алу осях... никаких проблем от них не слышал... колеса в идеальном состоянии, и ездят не вокруг дома, а наматывают приличный километраж.
vk.com/palermo2400
skype: palermo2400
LinuxUser
СообщениеДобавлено: 22.12.2012 00:21
Это относилось к втулкам 2008го года, как раз когда серия 775 была первый год. Причем, если не ошибаюсь, относилось только к некоторым сериям колес XT фабричной сборки. Массовых проблем вроде не было. Моя такая втулка за 4 года не клинила, к счастью :smile:
Felt NinePro & Giant Reign
СообщениеДобавлено: 22.12.2012 01:05
2 palermo2400
Т.е. получается английцы свистят, а оф. представитель для укрепления имиджа марки признал несуществующую проблему?
Шото тут не сходится.
СообщениеДобавлено: 22.12.2012 01:10
2 C_Zone
Год я точно не помню, но вопрос не в годах, а в том что в старших группах оборудования каждую серию идут косяки.
Китаезы вообще обнаглели, они походу даже испытаний не проводят...
СообщениеДобавлено: 22.12.2012 01:25
Да ладно, а у остальных производителей в старших сериях косяков не бывает?
Ну и маленькое выступление Капитана Очевидность: дефекты случаются, даже в очень дорогих вещах, касается не только вело.
СообщениеДобавлено: 22.12.2012 13:31
Расскажите плиз что то конкретное по вопросу прямые спицы vs обычные.
СообщениеДобавлено: 22.12.2012 13:44
Конкретно - прямые лучше.
[ Time : 0.284s | 28 Queries | GZIP : On ]
