Подскажите с выбором двухподвеса для покатушей по лесам, горам и городу.
Итак начнем:
2012Kellys_ROUGE2.jpg [ 223.23 КБ | Просмотров: 2761 ]
Велосипед Kellys ROGUE (2012)РАМА Kellys SFS Superlite SDWT 7005 3ple butted 115mm r
ВИЛКА Fox 32 Float RL 120mm, air / Open Bath / Lockout
РУЛ. КОЛОНКА KLS Expert integrated
КАРЕТКА -
СИСТ. ШАТУНОВ KLS Race integrated (44x32x22)
П.ПЕРЕКЛЮЧАТЕЛЬ Shimano Deore M591
З.ПЕРЕКЛЮЧАТЕЛЬ Shimano Deore M591
МАНЕТКИ Shimano Deore SL-M590 Rapidfire Plus
КОЛ. СКОРОСТЕЙ 27
КАССЕТА Shimano CS-HG50-9 (11-34)
ЦЕПЬ KMC Z99
ТОРМОЗА KLS Helix 3 Hydraulic Disc
ТОРМ. РУЧКИ KLS Helix 3
ВТУЛКИ Sram MTH-306 Disc
ОБОДА KLS Draft Disc 559x19 32holes
ПОКРЫШКИ Schwalbe Rocket Ron Performance 26 x 2.25 fold.
ВЫНОС KLS Expert
РУЛЬ KLS Expert RiseBar
ПОДСЕД. ШТЫРЬ KLS Master
СЕДЛО Selle Royal Mach
ПЕДАЛИ KLS Master - alloy
ЗАДНИЙ АМОРТИЗАТОР Fox Float RL air / ProPedal / Lockout
ВЕС 14,10 (440mm)
РУЧКИ РУЛЯ Kellys Codex 2Density
Specialized Camber Expert (2011)Вложение:
camber-expert-2011.jpg [ 100.97 КБ | Просмотров: 2761 ]
FRAME M4 hydroformed tubing, sealed cartridge bearing pivots, disc only, Command Post routing, replaceable deraileur hanger, bolt on cable guides, 120mm travel
REAR SHOCK Custom Fox Triad II for Specialized, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal, rebound adj., 7.875x2.0"
FORK Custom RockShox Reba TK, Turn Key damper, Solo Air, alloy steerer, rebound adj. w/ LO, disc only, 120mm travel
HEADSET 1 1/8" upper and lower campy style cartridge bearings for integrated alloy HT
STEM Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise
HANDLEBARS Specialized XC low-rise bar, 2014 butted alloy, 680mm wide, 8 degree back sweep, 6 degree up, 31.8mm
GRIPS Specialized lock-on, S/M: Grappler, Other: Rocca
FRONT BRAKE Custom Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, G3 Clean Sweep rotor, S/M: 185mm, L/XL: 203mm
REAR BRAKE Custom Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, G3 Clean Sweep rotor, S/M: 160mm, L/XL: 185mm
BRAKE LEVERS Avid Elixir 5 hydraulic
FRONT DERAILLEUR Shimano FD-M660-10E SLX, 10-speed, E-type for DMD, top swing, bottom pull
REAR DERAILLEUR Shimano RD-M772 Deore XT Shadow, 10-speed, long cage
SHIFT LEVERS Shimano SL-M660-10R SLX, 10-speed, trigger
CASSETTE Shimano HG81, 10-speed, 11-36t
CHAIN KMC X10, 10-speed, w/ reuseable Missing Link, nickel plates
CRANKSET Shimano FC-M552, Hollowtech, 10-speed triple, replaceable rings, S: 170mm, others: 175mm
CHAINRINGS 42A x 32A x 24S
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing
PEDALS Resin Test Ride Pedals with toe clips, CEN std.
RIMS[ Custom DT Swiss 445D, alloy disc, double wall, pin joint, eyelets, 24mm, 28/32h
FRONT HUB Specialized Hi Lo disc, laser-etched logo, OS 28 end caps, sealed cartridge bearing, RWS, 28h
REAR HUB Specialized Hi Lo disc, lasere-etched logo, double sealed cartridge bearing, QR, 32h
SPOKES 1.8mm (15g) stainless
FRONT TIRE S-Works "The Captain", 120 TPI, 2Bliss ready aramid bead, dual compound, 26x2.0"
REAR TIRE Specialized "The Captain" Control, 60 TPI, 2Bliss ready aramid bead, dual compound, 26x2.0"
INNER TUBES Ultralight presta valve
SADDLE Specialized BG Henge Comp, hollow Cr-Mo rails, 143mm width
SEATPOST 6061 alloy, 2-bolt micro adjust, setback head, 30.9mm, S/M:350mm, others:400mm
SEAT BINDER 34.9mm clamp ID, alloy collar w/ QR, black
Giant TRANCE X 4 (2011)Вложение:
Trance_X_4_wht_red.jpg [ 225.83 КБ | Просмотров: 2760 ]
РАМАКонструкція ALUXX SL-Grade Aluminum, 5" Maestro Suspension
Вилка RockShox Tora TK w/ Tapered Steerer, 120mm Travel
Амортизатор задній Giant Air
КОМПОНЕНТИКермо Giant Connect, Low Rise 31.8
Винос керма Giant Connect
Винос сідла Giant Connect, 30.9
Сідло Giant Performance MTB
Педалі Alloy Platform
ПРИВІДМанетки Shimano Alivio, Rapidfire
Перемикач передній Shimano Alivio
Перемикач задній Shimano Deore, Top Normal
Гальма Shimano M445
Важелі гальм Shimano M445
Касета Shimano Deore 11x34, 9-Speed
Ланцюг Shimano HG73
Система шатунів Shimano M542, 22/32/44
Каретка Shimano Press Fit
КОЛЕСАОбоди Giant S-XC2
Втулки Formula Alloy Disc, 32h
Спиці Stainless, 14g
Шини Kenda Nevegal, 60 tpi, 26x2.1 Folding
