| https://veliki.com.ua/dir_bikes.htm |
СообщениеДобавлено: 26.02.2009 17:29
а зачем ими пользоваться при стирке курток-штанов не говоря уже про обувь?
Опыт туриста определяется умением использовать в походе не нужные вещи взамен забытых дома нужных!
СообщениеДобавлено: 26.02.2009 18:12
просто в составе многих порошков уже включены ополаскиватели ..
СообщениеДобавлено: 26.02.2009 18:31
В общем, получил официальный ответ.
Вотъ.
CARE AND IMPREGNATION INSTRUCTIONS
1. Washing
· Please read first the garment manufacturer's care instructions on
the sewn in care label.
· For normal degree of soiling please use gentle washing program and mild detergent.
· For heavy degree of soiling please use a pre-wash treatment with
detergent booster first.
· To prevent detergent residues on GORE-TEX® material please rinse
garment thoroughly (repeat rinsing process)
· Do not use fabric softener !
· Frequent washing does not reduce breathability.
2. Impregnation
· Washed garments need to be impregnated.
· After 3 – 4 washing cycles impregnate with impregnation spray (for
example Granger`s from Salewa, Tokko from Mammut or similar products from other suppliers)
· The impregnation does not improve the waterproof property of the
GORE-TEX® membrane but it covers the fibre of the face fabric in order
to repel water and soil.
· The impregnation should restore water- and soil-repellent effect
of face fabric.
· The wicking effect of the face fabric will be clearly reduced so
that moisture cannot be transported through seams to the inside.
· Ironing according to care instructions or tumbling with low
temperature can re-activate the impregnation effect and maintain the
hydrophobic characteristic of the face fabric.
· Recommendation: Sports- and streetwear garments should be
post- impregnated after 3-4 washing cycles
3. Care of motorbike garments with GORE-TEX® material
· We recommend cleaning and impregnation of motorbike garments at a dry cleaner which can guarantee a balanced distribution of impregnation agent.
Important:
Rather wash your garment regularly
without or less detergent
than rarely with a lot.
Best regards
W.L. Gore & Associates GmbH
Consumer Service
Stefanie roth
Tel. +49 (0)8063 -80-1712
Fax +49 (0) 89 4612 4 1712
mailto: [email protected]
http://www.gore.com
http://www.gore-tex.de
http://www.windstopper.de
СообщениеДобавлено: 26.02.2009 21:31
ага,понятно..
лучше: чаще, но -меньше, а не : реже и больше :D
и все-таки без ополаскивателя.. :D
приятно , что ответ получил..
СообщениеДобавлено: 27.02.2009 13:08
а если вкратце на русском-че там пишут? лень идти словарь искать...
СообщениеДобавлено: 27.02.2009 14:39
вкратце:
стирать согласно написанному на лейбле;
выбирать мягкий режим стирки;
не пользоваться смягчителями для тканей;
стирать слабые загрязнения с меньшим кол-вом порошка- лучше , чем редко стирать очень грязную вещь с большим кол-вом порошка;
после стирки вещи пропитывают (?после 3-4 раз стирки?)
СообщениеДобавлено: 27.02.2009 17:25
а как узнать есть ли в составе порошка смягчитель? да и с шампунем для стирки не ясно...
СообщениеДобавлено: 27.02.2009 19:44
про добавки обычно пишут на пачке порошка..:-)
про шампунь не скажу- не пробовала..
на опыте моей флисовой пончи с мембраной определила, что лучше стирать просто в воде(когда она не очень грязная)..
когда-то постирала с ополаскивателем, - результат плачевный :( , волокна залипли, как-то..
а вообще любая вещь имеет свой срок и при при интенсивном использовании темболее..
СообщениеДобавлено: 28.02.2009 13:03
Ну и что бы поставить окончательную точку. На лейбле Бергсона с мембранной Supra-TEX XP5000 нарисовано:
1. Стирка изделий с нейтральными моющими средствами в холодной воде, при максимальное температуре 30°С.
2. Нельзя выжимать и сушить в стиральной машине или электросушилке
3. Не отбеливать, нельзя использовать хлоросодержащие моющие средства и стиральные порошки с отбеливателями
4. Не подвергать химчистке
5. Не утюжить
Так что все очевидно. :-)
Перевести иероглифы можно при помощи этой странички http://www.lafei-nier.ru/publications/?id=6&p=0
СообщениеДобавлено: 28.02.2009 18:14
что такое нейтральные моющие средства?
СообщениеДобавлено: 28.02.2009 18:48
Мда..действительно..Вот как это "нейтральные"...Дестилированная вода что-ли?
Спасибо за интересную тему. Действительно, многие при таком вопросе сразу говорили : "А поискать в интернете?"...Но в инете искал,как и многие товарищи здесь, - и вроде как и тема должна быть известная и популярная, но с другой стороны, - ведь никто ничего и не говорит!
Да, все говорят - "а вы не забудьте пройтись пропиткой после того как постирали"..Ну так а в чём, в чём, как стирать-то? Тут сразу молчание...
Или "У тябя ботинки на Гортексе" - "Да" - "А как надо ухаживать?" - "Ну как,как ...ты что не знаешь?" -"нет!" "Пф....ну такие вещи элементарные" ...- и главное, ушел, и не сказал какие.. :D Так в своей жизни пока никакого ответа не получил, зато все вокруг жутко умные, а сам получается не очень.. :D :D
Ну вот скажем у меня мембранная куртка. Езжу в ней на велике.Уже загрязнилась - рукава и шея...от штанов зимних от пыли черные полосы с внутренней стороны. Хотелось бы отчистить.. Что, только в воде? Ну хоть с детским мылом можно? Или с хозяйственным...но там жуткая щелочная среда...ПАВ, по определнию в обоих быть должно,- этож мыло....Или спец средсвами , что в магазине...но написали же - это уже после стирки...
Короче, я в недоумении. Вот за обычными ботинками Экко, как ухаживать....Чистить можно или нельзя...Или чем, если можно...Или вообще нет такой необходимости...А мыть-стирать..А брызгать на них можно/нужно водооталкивающими пропитками или они сами по себе должны быть непромокаймыми..
Или вот "не хлоросодержащими средствами"...гм...у нас вода само по себе хлоросодержащая...Не белизна, конечно, но и сама по себе ничего так отбелить за сутки может. :-) Разве что отстаивать как для аквариума для стирки..
P.S. Перечитал еще раз...
1 . Понял, что один человек стирал Тайдом (спасибо, хоть прямо написал :-) )...Ну уж не знаю, неужели он без отбелевателей и имеет нейтральную среду?...почему именно Тайдом, тогда возникает вопрос.. :( а другие пойдут порошки...
2 .Еще отстировали в чистой воде, ну это понятно...но не тот случай...
ясности для себя как-то не обрел еще....буду думать и еще раз перечитывать.
Официальный ответ, конечно, мутный-мутный и больше отписку напоминает. Я их понимаю, -они бояться, чтоб не дай Бог, где-нибудь лишней рекоамы не было...Это понятно.
Но меня бы, да, лично, конечно устраивал ответ - стирать тем-то и так-то и будет нормально. :D
СообщениеДобавлено: 02.03.2009 11:39
1 . Понял, что один человек стирал Тайдом (спасибо, хоть прямо написал Smile )...Ну уж не знаю, неужели он без отбелевателей и имеет нейтральную среду?...почему именно Тайдом, тогда возникает вопрос.. Sad а другие пойдут порошки...
В Экстриме говорят, что с хозяйтсвенным мылом можно, а вот с тайдом нельзя. Им я верю, в принципе мембрана бергсоновская прожила 2 года.
У меня мембранные ботинки Ла-Спортива и Лайтос (с Экко должно быть всё так же). Всегда беру нубуковые. Нубук чищю спец резинкой или резиновой щёткой. Если сильно грязный, той же щёткой под проточной водой. Пропитка для обуви Никвакс - она не брызгается, а идёт с губкой, которой нужно обувь натирать. Определяю когда пропитывать "на глазок": когда первые капли не отлетают от нубука, а нубук становится влажным.
Пропала собака, цвет черный, порвано правое ухо, один глаз вытек, на спине вырван клок шерсти, задняя левая лапа перебинтована, передней правой нет - когда писает, падает - откликается на кличку Счастливчик.
:velo3:
СообщениеДобавлено: 02.03.2009 11:41
1. Без отбеливателя - тут вроде все очевидно.
2. Без смягчителя - смягчитель воды использутеся почти во всех порошках для машин-автоматов -> берем для ручной стирки
3. Без леноров и тд.
Итого: лучше всего подходит дешманский "лотос" для цветного белья и ручной стирки. :D
В него точно "закрутителей" не накидали. Если боишься порошков - возьми хорошее жидкое мыло: в нем точно нет отбеливателя, смягчителя воды, антистатика и другой химии. И рН у него не кошмарный. В общем - нейтрально оно со всех сторон, я изначально подсознательно им пользовался. Теперь понимаю - что я был прав! :-)
СообщениеДобавлено: 02.03.2009 14:54
каким жидким мылом, которым руки моют или в стиральную машину льют?
СообщениеДобавлено: 03.03.2009 15:46
РУКИ!!!
жидкий "порошек" для стиральной машины может быть и отбеливающим, и смягчающим и тд.
Мыло, и гм.... это.... ну.... для интимных мест. :oops:
Оно, как я понимаю самое нехимическое. - но это уже мои домыслы.
[ Time : 0.178s | 27 Queries | GZIP : On ]
