| veliki.com.ua/dir_computer.htm |
Начать новую тему Ответить на тему На страницу Пред.  1 ... 314, 315, 316, 317, 318, 319, 320 ... 357, Bce  След.
СообщениеДобавлено: 12.12.2017 00:25
Самые "лечебные", RotoЯ - они дороже. :yes:
СообщениеДобавлено: 12.12.2017 01:49
Простите, коллеги - лень таскать тудасюда фото, просто дам ссыль на пост (интересны, как мне кажется, фото начиная со второй): http://forum.velomania.ru/showthread.ph ... ost6953148
Если не сюда - мои извинения. Но в ПАБе там сейчас вроде более важные вещи обсуждаются. :mad:
Тут ещё пара прикольных фото: http://forum.velomania.ru/showthread.ph ... ost6953440
Последний раз редактировалось Kotofej 13.12.2017 00:11, всего редактировалось 1 раз.
СообщениеДобавлено: 12.12.2017 11:32
Изображение2_5294426711427907989 by Aleksei Flopus, on Flickr
Изображение2_5294426711427907990 by Aleksei Flopus, on Flickr
СообщениеДобавлено: 12.12.2017 13:22
Изображения: 48
Some French bicycles (and many early Treks!) came with Maillard "Helicomatic" rear hubs. This was the first cluster that could be removed without a big, powerful tool. It came with a cute little pocket-size tool that incorporated a spline wrench for the cassette lockring, a spoke wrench, and a bottle opener. The Helicomatic was a nice idea on paper, but poorly executed. These hubs are losers.
Both hub flanges were 1mm farther to the left than those of a normal hub, causing increased dish in the rear wheel, and persistent spoke breakage problems. Many loyal Helicomatic fans tout the ease with which the cassette may be removed for spoke replacement as a great virtue, but if the hub were better designed, it wouldn't break so many spokes!
These hubs were prone to bearing problems as well. Due to clearance requirements, they couldn't fit the normal 9 1/4" bearing balls, so they used 13 5/32" balls on the right side. These didn't hold up well. The cones tended to wear rapidly, and replacement cones are no longer available to fit these hubs.
Тем не менее не 40 ньютонметров, и хлыст по идее не нужен :smile:
No gods, no masters
СообщениеДобавлено: 12.12.2017 13:28
на картинках то одно, а вживую иншэ)))
СообщениеДобавлено: 12.12.2017 13:31
Изображения: 48
Та я ж не против, сам недавно узнал про их существование, а тут повод блеснуть знанием :D
No gods, no masters
СообщениеДобавлено: 13.12.2017 04:12
СообщениеДобавлено: 13.12.2017 04:58
Как только скорость переключить...
СообщениеДобавлено: 13.12.2017 06:48
СообщениеДобавлено: 24.12.2017 12:52
СообщениеДобавлено: 27.12.2017 22:13
Kirill Yevtushenko писал(а):
А это из 70-х; с индикаторами.
Круто. Благодарю. Ежели дойдут лапки до изготовления более путного колёсоровнятельного аппарата - обязательно попользую.
СообщениеДобавлено: 28.12.2017 04:33
Вот такие усовершенствования...
shedevry-nastoyashhix-masterov-remonta-163.jpg [ 50 КБ | Просмотров: 2728 ]
shedevry-nastoyashhix-masterov-remonta-214.jpg [ 65.37 КБ | Просмотров: 2728 ]
СообщениеДобавлено: 15.01.2018 22:46
Я так хочу быть c тобой,
Но не могу здесь.
Воздух!!! Мне нужен воздух!
iznos_cepi.jpg [ 155.7 КБ | Просмотров: 2614 ]
СообщениеДобавлено: 15.01.2018 23:30
Встречал - http://velo-sport.sumy.ua/forum/viewtop ... 075#p68075
СообщениеДобавлено: 16.01.2018 00:47
Педальку нужно было контактную, или, хотя бы, туклипс - тогда ногой крутить можно. :D Сразу, и тренировка и по хозяйству помог. :wink:
[ Time : 0.105s | 29 Queries | GZIP : On ]
