| veliki.com.ua/dir_kids_bikes.htm |
 Заголовок сообщения: Specialized Stumpjumper FSR Comp
СообщениеДобавлено: 07.02.2013 20:31
Решил добавить в свою конюшню вот такой пепелац для трейла и гор самое оно)))), из ощущений катит лучше, чем скотт спарк 60, ну и обработка всяких там неровностей фоксом просто класс.
Сейчас вдуто в вилку 85пси /180 пси в аморт на вес 82 кг как раз нормально
Спецификация:
FRAME
FSR M5 manipulated alloy frame w/ Transform monocoque TT, sealed cartridge bearing pivots and rear shock mount, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 120mm travel
REAR SHOCK
Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.75x1.75"
FORK
Fox Float 130 RL, 130mm, rebound/compression adj, lock out, alloy steerer
HEADSET
1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM
Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
HANDLEBARS
Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
TAPE / GRIPS
Specialized MTB, dual density
FRONT BRAKE
Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor
REAR BRAKE
Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL 185mm rotor
BRAKE LEVERS
Avid Juicy 5
FRONT DERAILLEUR
Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
REAR DERAILLEUR
SRAM X-9, 9-speed, long cage
SHIFT LEVERS
SRAM X-7, aluminum trigger 9-speed
CASSETTE / FREEWHEEL
Shimano HG50, 9-speed, 11/34t
CHAIN
SRAM PC-971 w /Power Link
CRANKSET
Truvativ Stylo, 2pc crank/BB
CHAINRINGS
22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET
Truvativ GXP, sealed outboard cartridge bearing
PEDALS
Wellgo MG-1
RIMS
DT custom for Specialized X430, 24mm w/eyelets, 32h
FRONT HUB
Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
REAR HUB
Shimano M-525 disc, 32h, alloy QR
SPOKES
DT Swiss 1.8mm stainless, black, alloy nipples
FRONT TIRE
Scwable nobby nic 26/2,25 EVO
REAR TIRE
TUBES
Specialized Ultralight 26x2.12", presta
SADDLE
Specialized BG Rival, hollow Cro-Mo rails
SEAT POST
2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDER
7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
NOTES
Protective clear coat, derailleur hanger, reflectors, owners manual
IMG_1904.jpg [ 80.21 КБ | Просмотров: 2463 ]
 Заголовок сообщения: Re: Specialized Stumpjumper FSR Comp
СообщениеДобавлено: 07.02.2013 20:43
Это года около 2008ого? и какого года спарк?
СообщениеДобавлено: 07.02.2013 20:46
этот 2007 года, спарк 2012)))
СообщениеДобавлено: 07.02.2013 20:50
Изображения: 37
А бутылочку удобно доставать? :smile:
СообщениеДобавлено: 07.02.2013 20:57
ну если пить хочеться то удобно)))), вкратце выбор пал на данную модель так как захотелось перейти на трейл, ну компоненты ничего так ушатать сложно)))
СообщениеДобавлено: 08.02.2013 01:10
можно посоветовать подфляжник specialized zee - отлично держит флягу, очень удобно доставать, малый вес если пластиковый, достаточно крепкий.
касаемо ушатывания компонентов - следите за ободами. они к сожалению печальны, и это у спеша уже не первый год..
всё по личному опыту.
spark rc 700 sl
СообщениеДобавлено: 07.05.2013 22:16
+1 сегодня только из мастерской- при лёгком весе обода они не прочные (если агрессивно кататься, они слабоваты...)
[ Time : 0.093s | 21 Queries | GZIP : On ]
